illestFX35
- 2010 FX35 RWD
So if I want to run Stainless Steel braided lines, I would buy the ones for the FX35 and then I may need a modified banjo bolt. Sound about right?
I bought the stop tech performance brake pads that caw with the package that zebra made for me. The calipers I purchased from circle-Infiniti on eBay. Just the calipers are $999 and the calipers with the hardware are like$1300. The thing is that I just checked on their eBay store and they don't appear to be selling them anymore. My calipers were actually purchased by my wife and there was member here that was selling a complete set for cheap but I don't want to put his name bc I don't want to brake a forum rule. Hopefully he sees it and chimes in. Good luck with the upgrade which by looks alone makes the vehicle look betterWhich Akebono pads did you have?
And OCAL - where did you buy just the calipers? Anything else needed (brackets, pins) if you buy the pieces individually?
I actually just went on the eBay store for circle Infiniti where I bought the calipers and now they are asking $1300 for just the four of them and $1600 for all four calipers and the hardware. This is the second time I have noticed that they increased the prices big time. At one point they used to have just the four calipers for like $900 and the whole set plus the hardware for $1100Which Akebono pads did you have?
i believe you get everything from CZP^ That sucks! So CZP at ~$2K with pads and rotors isn't bad. What other hardware is needed?
Hopefully this other member chimes in.![]()
I don't think the guy even knew what he was talking about. C when I said the sports brake calipers are the same from 09 and different models use them so you are trying to tell me that if I get my brakes done here you can't figure it out. He said they would have to grab the caliper and se which pads worked. Maudie a reason to charge more hourly lol
