Asua78
What's up everyone it's been a while, but I'm finally back after doing a lot of research for my '04 FX35 VQ35DE and here's the list of parts and upgrades being ordered with pictures as parts come in that will be installed by myself and other calculated parts at my local tuning shop. In total we're looking about almost $16,000 for parts, but so worth it in the long run. So here's the goodies being purchased.....
1.) Z1 VQ35DE Basic Engine Rebuild Kit "Level 3" w/ ARP L19 Head Studs, Carillo Super "A" Connecting Rods + Piston Ring Compressor
Bore Size: 95.5mm / Compression Ratio 8.8
2.) VQ35DE Rear Timing Cover Oil Gallery Gasket Kit w/ Hardware
3.) Z1MOTORSPORTS VQ35DE 75MM Throttle Body Upgrade w/ Adapter Pigtail
4.) Tomei Poncam VQ35DE Performance Camshaft Set "Non-Revup"
5.) Brian Crower VQ35DE Stroker Crankshaft
6.) AFE Power Takeda Stage-2 Cold Air Intake System Pro w/ Dry "S" Filter (MAF Sensor)
7.) Invidia Gemini FX35 Cat Back Exhaust System
8.) OEM MAF Sensor Bolts (2)
9.) OEM Thermostat Housing Bolt (VQ35DE)
10.) Z1 Aluminum Coolant Bleeder Port (HH)
11.) King VQ35DE XP Race Series "M.B. Kit"
12.) Injector Dynamics Fuel Injector P & P Adapter Connectors (6)
13.) OEM Fuel Injector Clips (6)
14.) VQ35DE Timing Cover O-Ring & Seal Kit "plus extras"
15.) OEM VQ35DE F.I. O-Ring Set (4 Sets)
16.) OEM FX35 VQ35DE Timing Kit w/ Tensioners
17.) OEM Crank Pulley Bolt
18.) Z1 VQ35DE "Lightweight" Crank Pulley Kit
19.) Z1 VQ35DE Oil Pan Spacer w/ Hardware + O.R.P.
20.) OEM VQ35DE MAF Sensor
21.) OEM VQ35DE Front Crank Seal
22.) OEM VQ35DE Thermostat Gasket
23.) Z1MOTORSPORTS "H.P." Radiator Cap
24.) OEM Rear Main Seal & Retainer
25.) Mishimoto Low Temp Thermostat
26.) OEM VQ35DE F.I. Sub-Harness Wiring
27.) Deatschwerks VQ35DE Drop-in F.I. 650cc (6)
28.) Kinetix VQ35DE Velocity Manifold Kit w/ Polycarbonate Cover
29.) Tomei Extreme VQ35DE Exhaust Header Kit w/ Full Hardware Kit (Titanium Exhaust Wrap)
So that's about it for now, so as soon as the parts come in I'll be back to post the process of the project for "Silver Bullet"
