- Atlanta, GA
- 2007 FX35
My personal experience with the no name chinese vinyl is that its ok for large surfaces, but if you use it for areas you have to stretch a lot, it will come up lacking. Also, the adhesive isn't as aggressive. Right now I have 3M CF and brushed, hexis, and some generic green cf. The 3M and hexis are almost indistinguishable from each other. But the generic CF is different. It doesn't stick as well and is harder to stretch, also it tears easier when heated. On the FX, it would be fine since most of the edges are covered by the black trim. But if you had a car with a ton of angles and lots of exposed edges that could lift, I don't think it would work well.
