White Smoke blowing out from the pipes
NivZ
IS
FX 35
Niv
Hey,
I’ve got Infiniti FX35 model 04’, a week ago I’ve turned on the vehicle and drove, a few minutes later a white smoke begun to blow out after a few minutes it stopped, a day later in the morning I’ve turned on the engine and the issue happened non-stop, and every time I reved more smoke came out, is it a issue that can be fixed or the engine is going to die?
I am linking a video that I took.
Thanks in advance!
Looks like engine is burning coolant. It doesnt blow any smoke when warmed up?
The engine isn’t warming and it’s temperature is normal. as you can see by the video, the vehicle blows a white smoke when I just turning the engine and then when I press the gas pedal it blows a much more smoke.
Have you solved it? If it smokes on startup and goes away, replace your PCV valves. Ive been through this. Don't clean them, replace them.
