Which is Daytime Running Light Fuse?
roughx021
Stony Brook
2010 FX35
I have searched and cannot find the answer. I have checked all 3 fuse boxes and cannot find a bad fuse. Which fuse exactly controls Daytime running light. It comea on with the oarking lights, but doesnt turn on with ignition Without lights on.
It isn't programmed to come on for the US market. You have to wire it to come on. There should be a DIY floating around here.
Has anyone been able to get the dealer to turn it on via Consult?
I could have sworn they used to come on with the ignition. So the DRL only comes on with parking lights? When i get angel eye rings, i want them to come on as DRL. Anyone know how to wire this?
Nope, it only comes on with headlights. To have the AE comes on with car running, just tap into the ACC wire (wire that energize when car run) by the ignition switch. I take a pic an post it up here later.
Here is the pic where to tap into for ACC wire so the AE will turn on when key is in ACC and RUN.
I added a toggle switch with a relay so that I can turn on/off the AE when the car is running.
Take the knee panel off. It's mounted under the steering column. Can't miss it. You can get to it without taking the knee panel off, but it may be a bit of challenge to get to the wire.
Thats good to know that ACC wire location. I powered my halo rings off the "DTRL" mod from the org. (Not really DTRL Its also giving ACC power. I still want to make it true DTRL, having it go to low-beam with the headlights on, and only on when the engine is on / car is in drive.)
When y'all say "tap," what exactly do y'all mean? Like cutting the wire open?
Sent from my SGH-T999 2
