kang
- Miex, Valais, Switzerland
- FX45 2004
Hello Guys,
May I kindly ask for your help?
I need to find a way to take the reverse signal on my FX45 2003.
I tried to find the signal on all the plug inside the centre of the car. Every positions on the plugs who go to the radio, air-con, ... and also under the shift panel.
Unfortunately, I cannot find a way to have only the reverse signal :-(
I also check the wiring schema that we can find here:
http://x.infinitihelp.com/forum/local_links.php?catid=9#.UX0bQLU9F8E
I don't want to install a cable from the back of the car to the front.
The next step will be to find the plug: Back-Up Lamp Relay (B44) or the Transmission Control Module (F44) or the Display Control Unit (M75 terminal 8) or in the plug from the Audio Unit (M58 terminal 6) or in the A/C and AV Switch (M64 terminal 1)
On my car, I don't have any Display Control Unit, only a Display Unit (Orange screen) and no signal on the M58 terminal 6 nor on M64 terminal 1 related to the reverse.
Could you please help me to find the B44 or F44 plugs?
Could you please help me to find the reverse signal?
Thanks for your help.
I'm stuck with this signal around 6 hours now ;-(
