black_stallion
- Chicago
Got a 2003 fx45, rear brakes need replacement very bad but i cant take the drivers side rear wheel off. Its stuck and wont budge. Help!!!!!!!!!!
tried everything i could think of. i hate driving around hearing the brakes sqeakingwd40 and some brawn =)
nothing sighTry tapping the nut a little.
all the lug nuts are off and the tire is completely off the ground. the problem is that the wheel seems to be stuck to the studs or rotor. i had this problem before in my civic but i was able to hit the wheel till it came off
havent tried this one. im exhausted though lol ill try tommorrow. i changed the pads in the other side in less than 10 minutes, so its aggravating me more that this other wheel is not moving lol. even if i try to spin the wheel it will not spin. it only moves a few inches to either side. its awd maybe thats why the wheel wont move muchHave the wheel off the ground and kick it while rotating the wheels from each corner.
thanks for the hintpb blaster in the hub hole of the rim and lug holes and wait a few hours. After... apply anti-seize between the rim and hub before placing the rim back on.
thanks will try if above hint dont workhit the rim from behind while turning it should work it out litle by little, you gotta kind of wiggle it off. absolute worse case you can thread the lugs in, then back out 1/2 turn basically leaving the lugs a little loose, then put it down & drive it a few feet, if it still don't lossen drive it a bit harder & in a turn, at some point it will definatley loosen & not damage anything in this really by doing this...
