What To Do With Vinyl Wrap?!
Denver
2003 Infiniti FX35 AWD
I've had this wrap sitting in my condo for about 5 months.
I saw the DIY on the grille, but not sure if I'll find a way to screw that up.
Has anyone done their side door panels. Mine have heat rash and faded. Figured that won't be too difficult.
What else have you guys done with your wrap?
Sent from my iPad
Not sure if you can wrap door panels due to their porous surface, so adhesion would be tricky if at all possible. The only thing on the door panels I've done and see no problem doing was the door handle, door lock handle and power windows surround, to go together with the center console, radio bezel, side vents, steering wheel and overhead sunglasses holder. That's on the inside.
I tried my grille with vinyl but feel like I got a cleaner look with paint, too many bumps lol. But give it a try :).
Pretty much you can wrap anything that has a solid and even surface.
Primer would be a good thing to use too.
Interior door panels? It actually would work, but it would be tricky. You would have to clean the surface very well, probably with acetone to get rid of any product on there. The prime it with adhesion promoter. Then wrap it, but you would have to use a ton of heat to make sure it sticks and conforms. Then heat again and again to make sure it doesn't lift. I've wrapped panels like that with grain and it does work, but requires more heat and pressure to ensure the vinyl stays.
