hi:
i have a FX35 2004 is on 60,000 miles and i'm not sure what OIL SAE to use i mean i use a 15 W 40, i would really appreciate if someone let me know what's the right oil to add to the engine.
Thanks
I use
Oil Filter- K&N HP-2010
Oil- Mobil 1 15w/20w (7quarts)
5W30 is the recommended oil by infiniti.
My car is up there in km's and a technician friend who works at infiniti said some cars benefit from moving up to a 5w40 weight. I tried it on a recent oil change and everything sounded a little smoother, so I'm sticking with that from now on.
15w20? 7 qts?
Your using oil that goes really far outside the recommended range by the engineers that built your car, and unless you have a high capacity oil pan, you are using 2 qts too much oil. Overfilling your oil is a dangerous game to play, you can literally drown your engine.
I believe fx45 is 6.5qts as I recall Infiniti issued TSB about overfilling. I have dealership put in 6 qts & I then add the 0.5 qt myself.FX35 takes 5 qts.
FX45 takes 7 qts.
03 fx45, 118k miles. I run Mobil One 0w-40 (synthetic). I burn about 1qt every 1,000 miles - has been since almost new. Dealer did a "short" block test & determined burn was not excessive. As such I do fill ups using walmart synthetic 5w-30 (cheapest synth) I could find.I have been using 10W30 Royal Purple for the last 2 years after advice from the forum that it would help with oil consumption. It is expensive oil, but I think it did help a little. On my next change, I am going to switch to 5W40 and switch brands given how much of it I have to buy with how much it is burning, and save some money.
Anyone that has an FX45 oil burner that has switched to 5W40, any brands you have found that help more than others?? Thanks!
