- Riverside, CA
I am recently having a problem where if the engine is Warmed up and shut down, there is a starting problem. The car cranks perfectly fine but every now and then, it would start then immediately die or it would start then the engine feel like it’s about to die then starts. I don’t have this problem when the car is cold. This only happens when the engine is warmed up. Anyone encounter this issue? I did all the basic stuff like check filter, clean maf sensor, and see if throttle bodies are clean. I suspect it is something related to injectors? This is in a 17 QX70 limited.
