VQ35HR Invidia resonator delete.
illestFX35
2010 FX35 RWD
How do I delete the resonator on the Invidia CBE? I never really understood what "resonator delete" meant. Can anyone explain? Which part do I replace with a straight pipe? (Yes, I'm still a noob)6aca4a18e871c8c1cfd731f05fcd2547.jpg
Those two barrel/tank looking things in the top right of the pic are resonators. They are usually located on the midpipes, as opposed to the mufflers which look similar, but are in the rear near the tips.
Different application (M5), but this gives you an idea visually:
Why would you resonator delete a cat back? The only reason people resonator delete their stock exhausts is that it's a cheap way to make it louder. The resonators on the Invidia are very small as it is and don't do much. Compare it to your OEM resonator size and you'll see. IIRC, the initial design for the Invidia didn't have resonators. They were added on a newer version because the drone was too much for most people.
