VQ35DE FX35 Sea Foam
I'll find some good info for you jumbo. If its so safe, why not just leave it in forever?
As far as the "thousands of people and the manufacturer..." part; How many people use "Z-Max"? Carol Shelby says its great so it must be right? That stuff has been proven to reduce bearing life but it still sells like hot cakes and has for years.
In the meantime, you can find the ingredients in Seafoam on the manufacturers
Why not leave it in? Because that's not the intent of the product. It's a cleanser. Wouldn't you agree that you don't leave any detergent on anything forever?
Comparing this product to another should be apples to apples. The Z-max products are singularly specific to fuel, engine and transmission (3 different products) and are sold as lubricants, not cleaners. Not a good comparison.
Just not sure what prompted you to take this position on Seafoam in the crank case - did you have a bad experience with it? Or know anybody that has?
I mean the REAL reason you don't leave it in. You don't leave it in because it would destroy the rubber seals and the interact with oil that's in the crank case, effectively removing (or best case reducing) the lubrication value of the oil. There are detergents in oil that are safe long term.
I was comparing the reputation and widespread use of Seafoam to that of Z-Max. ie, just because thousands of people use it and the manufacturer says it's great, doesn't mean it's harmless. It's a product, for sale, like any other. How about this for a comparison; Thousands of people smoke crack, the manufacturers say its great, and most people don't die from it... :tongue:
Don't get me wrong, I think it's great stuff (Seafoam, not crack) and I totally use it in my intake and gas tank. I even have two cans in my shed at this very moment. I was recently doing some research before I planned to use it in the oil for the first time, when I happened upon a very insightful review by a dude whom I thought was pretty smart. I'll try to find it for you... Anyway, that's what prompted me to investigate it further and I just can't find any logical reason to use it in the crank case. The reasons not to use it there are fairly obvious if you think about it: Possible damage, probably no help, no better than frequent oil changes, more often than not no "sludge" to begin with, etc...
Ok, I'm looking for "proof" starting.........now.
EDIT: Oh yeah, and pertaining to your question below about the plug fouling. It's because Seafoam contains a significant amount of pale oil, which is also why it smokes when added to the intake.
---------- Post added at 11:18 PM ---------- Previous post was at 09:21 PM ----------
Ok, I found the thread I was talking about above. This is what made me question the idea of putting Seafoam in with the oil. My subsequent research on this topic was to verify the guy's claims (which I found to be true) and to look into the specific ingredients. This thread is a great read for anyone thinking about using Seafoam. Interesting regardless...
Thread:
http://audiforums.com/forum/showthread.php?t=92596&highlight=seafoam
Some highlights...
Ingredients in Seafoam:
1 PALE OIL 4229 40-60%
2 NAPHTHA 20 25-35%
3 IPA 125 10-20%
Point:
"...yes it can help dislodge sludge, at the expense of lubrication. but if you actually have a sludge problem, removing it is not addressing the root cause..."
Addressing the claims on the Seafoam website. The thread is from 2008, some of the info on the Seafoam website has changed since:
"Ah what the hell, i decided to see what the sea foam company has to say about their product. What exactly do they claim it does? What does common sense and logic say when applied to their claims?
http://www.seafoamsales.com/motorTuneUpConsumer.htm
1.When your vehicle has a rough idle, hesitates, stalls, pings or has an after run problem – this is often due to carbon buildup.
-Yea, and that traffic jam in the morning is due to carbon buildup View attachment 171947 There are so many possible reasons for these symptoms, carbon being one of them. Pouring additives in oil/gas will not address the root cause of these issues even if it removed the carbon.
2.When your vehicle's fuel injectors need cleaning – this is often due to residue left on injectors from poor burning fuels and contaminants.
-So how is pouring low quality oil and rubbing alcohol in your gas going to clean it out?
3.When moisture needs to be removed from fuels or an anti gel or de-icer is needed – these conditions are due to condensation in the fuel tank and extreme cold weather creating gas line freeze or diesel fuel gelling.
-Im sorry but moisture can not be removed from fuel. It physically can not mix with fuel. It can get into your gas tank or lines, settling at the bottom. The rubbing alcohol can bond with both gas and water getting some of the water pumped out with the fuel. the real solution is to clean and decontaminate the tank and lines.
4.When there is moisture detected in the oil – this problem is due mostly to poor ventilation and condensation. Sometimes, however, there is a bad head gasket, cracked head or block that must be replaced.
-See above. oil and water do not mix. water would collect at the bottom of the crank case, making it fairly easy to remove, unless you have a massive amount from a blown head gasket. real solution (unless you have a $500 car): disassemble, hot tank. Adding solvent and low quality oil will not get water out of your motor.
5.When valve lifter noise is apparent or piston rings seem to be sticking – this is often due to dirty and gummed up oil passages, varnished lifters and buildup of gum, varnish and carbon in the piston ring areas.
-Same as #1, if you have these problems the root cause needs to be addressed, or you will blow your motor eventually. Adding solvent to oil and destroying its ability to lubricate wont help.
LMFAO!! :laugh::laugh:
Ok so your answer is no - you've never heard of anybody having problems from using Seafoam in the crank case.
The academic explanation sounds logical in theory - but without actual testimonials and experience it's just theory. And reading this guy's responsive answers - I think most of what he said is crap. A lot of generalization with no alternative suggestions. Whereas you can find the opposite - plenty of people who use the product in the crank case with no reported ill effects. People who use crack (to get high, not for their car) experience ill effects - documented medical fact.
I don't mean to slam, but academia and practicality are two different things. Real world data trumps the theory due to all the variables that can't be captured in formula. The stuff posted isn't even theory - it's just some dude talking (and not with any substance).
I really don't want to continue on and on and on with this - it seems to come down to faith for you. I also don't think a DIY thread is the proper place for such a discussion. Should have been a new thread referencing this DIY with your opinion.
No, I haven't ever put it in my crankcase and don't personally know anyone who has. I thought that part was implied when I answered your inquiry as to the reasoning for my stance on the subject. To summarize (and quote myself) "I just cant find any logical reason to use it in the crank case."
Subtracting the logic and theory leaves nothing but the ingredients. There are also no documented benefits to using it in the crank case.
Come on man, you have to know the smoking crack reference was a joke... :confused:
I guess I'm not very aware of the forum protocol. I actually didn't even notice that this was a DIY thread. This is the first and only time I've seen Seafoam referenced on this site, and I happen to have recently come across what I thought of as some interesting info pertaining to it's use. Sorry if I offended you with my blatant post contamination...
Interesting side note: The makers of Seafoam have recently revised their website. They now suggest two options for using Seafoam in the crank case; As a cleansing agent or an oil treatment. The first option suggests using it just before an oil change (similar to its traditional "tried and true" method), and the second suggests using the same amount and leaving it in indefinitely provided you adhere to the manufacturers oil change regimen. No changes have been made to the ingredients.
So is it safe to add it to motor oil??
I'm planning to do the followings in order:
1) pour 1/3 into the oil
2) remove the rubber cap and attach a vacuum hose
3) start up the engine
4) feed 1/3 seafoam thru the vacuum hose
5) shut off the car once the feeding is finished
6) let it sit for 5-10 minutes
7) start up the engine and let it idle for another 10-15 minutes
8) oil change
Am I missing anything in the list??
Reset the ecu and see if that cures it, if not you probably will have to do the idle learning process.
  1. ENGINE COLD
  2. Perform "Accelerator Pedal Released Position Learning" .
  3. Make sure that accelerator pedal is fully released.
  4. Turn ignition switch “ON” and wait at least 2 seconds.
  5. Turn ignition switch “OFF” wait at least 10 seconds.
  6. Turn ignition switch “ON” and wait at least 2 seconds.
  7. Turn ignition switch “OFF” wait at least 10 seconds.
  8. WAIT over 10 seconds before this next step.
  9. Perform "Throttle Valve Closed Position Learning" .
  10. Make sure that accelerator pedal is fully released.
  11. Turn ignition switch “ON”. WAIT EXACTLY ONE SECOND SHARP. Turn ignition switch “OFF”
  12. THEN wait at least 10 seconds.
  13. Make sure that throttle valve moves during above 10 seconds by confirming the operating sound. - Very hard to hear anything at all. Just believe this is happening by faith.
Now, here's the big change
  1. Start engine and warm it up to normal operating temperature.
AND RIDE YOUR CAR FOR AT LEAST 15 MINUTES, this will make for correct operating temperatures to happen within the engine for the following steps. Warming your car in the garage in the morning aparently does not cut it.
  1. Turn ignition switch “OFF” and wait at least 10 seconds.
  2. Confirm that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds.
  3. Repeat the following procedure quickly five times within 5 seconds.
  4. Fully depress the accelerator pedal. Fully release the accelerator pedal.
  5. Wait 7 seconds
  6. Fully depress the accelerator pedal and keep it for approx. 20 seconds until the MIL stops blinking and turns ON.
  7. Fully release the accelerator pedal within 3 seconds after the MIL goes off. Start engine and let it idle. THE ENGINE MUST BE STARTED WITHIN THE 3 SECONDS AFTER IT STOPS BLINKING, THATS HOW THIS LIGHT GOES OFF. THE SERVICE MANUAL DOES NOT STATE THIS, BUT IF YOU LOOK AT THE DIAGRAM WHERE THE ENGINE LINE ON-OFF IS, IT CLEARLY SHOWS YOU SHOULD TURN IT ON WITHIN THESE THREE SECONDS.
This is where your engine will start to learn the correct idle settings
  1. Wait 20 seconds.
  2. Rev up the engine two or three times and make sure that idle speed and ignition timing are within the specifications.
I had it just laying around, I am sure you can find it at your local auto store.... I have seen it in my local stores.
Hey guys. I am doing this right now. I just sucked 5oz in through the vacuum line. It sucked it in 3 seconds. The car barely got started before it was stalled. I got out and looked in the cup and it was empty! It has another 3 minutes to sit and I will start her up.
---------- Post added at 02:45 PM ---------- Previous post was at 01:55 PM ----------
Ok, all done. I put 1/3 in the tank too with 1/2 tank of gas. Idle already feels smoother. I hope my mpg improves.
tchuck is right i use to be a strong believer in seafoam as well but i will never put it in the crank case of my fx....my previous car was a mazda rx8 i used seafoam about 3 times in the crank case and after the third time about a month after my car started leaking oil....it is a very strong chemical and it does eat away at ur seals and gaskets....ps i still use it in my gas and intake...you guys wanted proof that seafoam damages seals here it is....i garbaged my 2008 rx8 because i was a believer in labels
