cigarette1
- In Front of You !!!
Here you go boys and girls (you know who you are)
This info is courtesy of Johnmax from the OTHER board :
Basically you need to break the reverse signal going to the display control unit, and the camera control unit. Using relays you have to send 12 volts to them on their reverse inputs, while breaking the wires to avoid sending power back the wrong way, which prevents the reverse lights from coming on and any other issues. The 2 relays are controlled by a switch which will turn the camera on only at will.
Your welcome
G
Your welcome
G
