there are 3 possible spacer designs, 1st are universal type, should never use them, we need hub centric spacers, universal spacers are sure to result in off centered wheels & vibrations & worse, possible but not really an option
the 2 options that are good are both going to be hub centric design, either straight bolt ons or ones that require longer replacement wheel studs. H&R's or ichibas are def the way to go for either of these types, stay away from imitation unknown quality crap out there
straight bolt ons of 20mm or more will fit & work with the stock wheels & are a decent option if your planning on changing wheels periodically, like winter stockers with spacers, but then custom summer 22's without spacers for summer use. the drawbacks to the straight bolt ons are that technically they are not as strong. you bolt the spacer on the orig studs w supplied short lug nuts & then the spacer itself has 5 new studs that project off of it & that's how the wheel mounts... the wheel is bolted on completely by the spacer which is aluminum, where in a conventional setup the wheel is bolted directly through the steel hub
the best way is the type of spacer that requires replacing the studs. they are more work to install & the drawback to them is you can have a problem trying to run a wheel without the spacers afterwards because the wheel studs will be longer, too long in many cases. not an issue though if your only running one set of wheels, or more of course even, as long as they can all acomidate the spacer too. the benifit of this design is it uses just 5 replacement studs for each wheel & they are installed directly through the steel hub, meaning a stronger wheel mount than the bolt on design.
bolt on's should be strong enough for casual use really, but I'd trust the replacement stud design personally much more & is def the prefered way to go, especially if you push your fx hard.
balancing & vibration issues come down to one thing only really with spacers, I mean all spacers are going to start out with a pefectly square block, so theres no way that the wheel will wobble or ocillate in/out or anything out of perfect alignment with the hub, so that's not an issue, the wheel will remain square & true to the hub even with spacers.
the only issue spacers have that cause all the vibration & wobbling is determined by how acuratley the spacer fits to the hub & then how acuratley the wheel fits to the spacer. we can assume that the spacers are lathe turned so they will be machined perfectly centered, BUT the problem comes when they are anything less than a tight press fit. many spacers slide on the hub but with a very slight amount of play. then, to compound this, the hub may fit to the wheel bore slightly loose too. in the end when you mount the wheel, if the hub-spacer has 8 thousanths excess clearance, & then the spacer-wheel fit has another 4 thousanths clearance, in the end the wheel will hang down 12 thousanths off perfectly centered when installed, then it is tightened in this slightly off centered location, bam, vibrations, percieved wobbling, all kinds of issues depending on how off these tolerances are. numbers used are for illustration perpose only & it may not be quite that much, never masured this actual tolerance differences
I have done one fx that had vibrations afterwards for this very reason. I solved the problem completely by removing the spacer & wrapping one thin layer of vinyl electrical tape at the hub surface, making the spacer a tight fit to the hub, centering problem solved there, the, same single vinyl tape layer to the spacer-wheel mating too, now, wheel goes on tight & centered, just like stock... ever notice you usually have to wiggle & pry the wheel off the hub when stock? it needs this tight fit to center perfectly, sloppy spacer fit is the culprit in most spacer troubles
tc6, thx for that great post, very educational.
