Vdc snow awd drive light on!
robcampbelljr
Denver
Hey guys!
I recently changed my front wheel bearings due to fact dealer quoted me 1000.00 After all said and done bought bearings for 300.00 Installed myself.
Now the problem all of my dash warning lights are on vdc snow awd brake ect are on??? Any help or suggestions would be helpful. Could i have installed sesnsors on wrong notch on wheel bearing assembly?
Did you forgot to reconnect the speed sensor? Was the hub mounted correctly that the speed sensor line up with the opening on the hub so it can "see" the teeth on the back of the hub. See picture 32 & 33 on this DIY, https://www.infinitiscene.com/search/1/?q=11012-HOW-TO-Replace-AWD-Front-Hub-Bearing-Assembly.
---------- Post added at 10:42 AM ---------- Previous post was at 10:40 AM ----------
Very possible that you did not have the sensor line up with the opening on the hub housing.
