Had the same lights couple days ago. Disappeared later. CEL stayed on. Was completely out of fuel on highway today(the gauge was showing 3/4 left,which I fixed 2 weeks ago(cleaning the contacts), scanned the code and it was P0461 Fuel sensor.
A code P0102 indicates the voltage from the MAF to the ECU is too low. I had it on the Bosch diagnose box at my causons garage and we found out the MAf has a constant 0.02 Volt as this need to be 1 till 1.5 and increasing when giving throttle. The Throttle Body responed we saw with increased voltage.
I swapped out the MAf sensor with one of a buddy of mine and did nothing. Cleaned my own and checked the wiring at the connector. Even cleaned the connector.
Now the wires at the connector make a direct 90 degree bent when coming out from the connector so i need to check that and am going to clean my TB tommorow just to be sure. Otherwise i need to find out wich pin at the ECM is the one the communicates with teh MAF so i can surch for any cracks in the wiring. Am doing a lot of google search right now,but no really defenit solutions i found yet......
