VDC off, Slip, Brake when cold but no codes to pull
jebjeb
Dallas
2003 FX35
Hey guys,
FX35 2005 134k miles
Seems last week when its cold the VDC/OFF Slip and Brake lights come on. This is normally first 5 miles of the morning. Stopped by Auto zone for a code pull and no error codes reported.
Had
Error code P0335 with vdc/off slip, brake lights and car stalled on Jan 30th 2015 and I replaced the Crank shaft sensor.
Is the crank sensor starting to go bad again?
Ended up being a rear right brake pad.
Left front was at 80% right front 80%
Left rear about 50% Right rear 5% if that
I suspect I have a sticking caliper. Going to check it in a few months to see.
Hope that you're replacing your rear pad right away before the pad backing grinds away your rotor.
Yep already did. May pull them again this weekend to test my caliper theory. Been about 3 weeks since I changed them.
You may have a seized caliper. In the previous vehicle, the right rear caliper was seized-up. I didn't even noticed until the vehicle pull a little to the right at higher speeds. I pulled the brake pads apart, and the rear right was wearing down significantly faster than the left side.
Any clue how much the repair was?
infiniti shows part number 44001-CL70B
CALIPER ASSY-RE $350 may have to make a run to pick and pull
