QX70 09+ Turn Signal LED
Discussion in 'QX70 Exterior' started by veritas, Mar 21, 2017.
  1. veritas
    veritas Member
    58
    40
    Los Angeles 818/213
    Car:
    2013 FX37
    Currently have changed the all the interior lights, DRL, and fogs. I was trying to change the turn signal to a switchback LED when I realized it only turns on as amber.. looked it up and there wasn't any solutions in some thread from 2013. Has anyone done it yet? Thanks
  2. Kanedean
    Kanedean Premium Member Premium
    335
    33
    Peace River, AB
    Car:
    2013 FX37 AWD
    The front turn signals are amber only bulb. You don't need switchback bulbs. If you really want switchback, you'll have to some wiring yourself.
    I'm running amber LEDs for my front turn signals, and they work great.
  3. nima
    nima Premium Member Premium
    461
    54
    Toronto, CA
    Car:
    2010 FX50S
    @Kanedean which bulbs are you using? brand/model?
  4. Kanedean
    335
    33
    Peace River, AB
    Car:
    2013 FX37 AWD
  5. nima
    461
    54
    Toronto, CA
    Car:
    2010 FX50S
    Do these not cause the different faster blinking rates?
  6. CMB4
    CMB4 Member
    48
    11
    Mass
    Car:
    17 Q70
    Name:
    Chris
    Same question
  7. illestFX35
    illestFX35 Member
    744
    197
    Los Angeles/Glendale
    Car:
    2010 FX35 RWD
    With any led turn signal you will need to wire load resistors so they don’t hyperflash
  8. E3A300
    E3A300 Member
    24
    8
    United Kingdom
    Car:
    2013 FX30D S Premium
  9. CMB4
    CMB4 Member
    48
    11
    Mass
    Car:
    17 Q70
    Name:
    Chris
    That's alot of wiring
  10. cv129
    cv129 Member
    9
    4
    Dallas, TX
    Car:
    09 370z Nismo 10 G37S Sedan 11 FX50
    Recently changed all exterior bulbs on my G and Z, contemplating on doing the FX too.
    G sedan uses a single bulb as turn signal ans DRL. I have just purchased (from Amazon) and installed that exact thing a couple of days ago. The base fits just snug enough into the socket to be secure (but does not lock in place however).
    The white is between 5000k and 6000k color, so won't match the OEM 4300k HID color.
    Those resistors run quite hot, I zip tied them instead of using double sided tape. Before putting my fender liner back together, I tested the bulb by leaving DRL on for 1 hour, then then signal for 15 minutes continuously (car connected to a battery tender). Thankfully they passed the test.
    Good thing is low cost + plug and play, great if you don't feel like doing the wiring yourself. More elegant and quality setups can be found on vleds.com.
  11. E3A300
    E3A300 Member
    24
    8
    United Kingdom
    Car:
    That's really great to know, so thanks for the feedback as I have just ordered some.
    How is the DRL function wired on your Z as I understand the turn signal part is just plug and play but I am trying to get my head around wiring up the DRL on an FX without a factory DRL?
  12. Jayden-FX
    Jayden-FX Member
    17
    14
    Toronto
    Car:
    2016 qx70s
    Name:
    jayden
    I got led Drl check out my post
  13. cv129
    cv129 Member
    9
    4
    Dallas, TX
    Car:
    In FX and Z's case, this bulb will only serve as turn signal. In the G, the same bulb serves as small light and turn signal, that's where this switchback bulb will work. For the FX, only the amber will come when turn signal is activated, the white LED won't light up.
    Edit: re-read your earlier post, seems like I'm repeating something you already knew. Sorry
  14. E3A300
    E3A300 Member
    24
    8
    United Kingdom
    Car:
    I appreciate the reply.
    Hopefully the wiring diagram might offer some information as the DRL function is used in a number of markets.
    Some working examples here:
  15. Pinstripe
    Pinstripe Member
    193
    57
    Canada
    Car:
    2013 FX37
    Our Canadian market FX's use the fogs as DRL's.
  16. CMB4
    CMB4 Member
    48
    11
    Mass
    Car:
    17 Q70
    Name:
    Chris
    I think I might end up doing that as our fog lights are useless.
  17. Old Blue
    Old Blue Member
    246
    44
    Spring TX
    Car:
    FX 37 rwd
    Name:
    Tom
    If you set your lights to Auto, and put a little electric tape over the eye on top of dash, voila, headlights light up every time you’re going, night and day.
    I know, not technically DRL, but they work fine, and I’ll bet you can’t think of a simpler way to convert US models with at least some sort of workaround running lights.:cool:
  18. DatMan
    DatMan Member
    654
    122
    Ottawa, ON
    Car:
    2007 FX35 AWD
    Name:
    Dat
    There was a fairly simple DIY for the 1st Gens...
  19. Old Blue
    Old Blue Member
    246
    44
    Spring TX
    Car:
    FX 37 rwd
    Name:
    Tom
    That’s what I did to my 03.
