sickarmor
Lots of work to do...
Thanks for sharing your experiences.
Thanks!
I have a bunch of things...Update
Mechanical:
Exterior:
- replace shocks, struts and springs in all 4 corners - BC Coilovers ordered: 12K/16K Spring rates F/R.
- replace rt side valve cover gasket - RTV Spark plug tube gasket leak hack (for now)
- replace thermostat
- replace transmission gaskets
- clean the throttle body, and plenum - cleaned MAS and throttle body
- replace (or hack-fix) the rear diff support bushing
- installed oil catch can
Interior:
- fix door dent
- replace front passenger door handle
- replace rear driver-side door handle
- clean up scratches, scrapes and sun damaged paint/clear coat
- fix short in driving lights
- replace broken antenna
- replace driver side weather stripping
As I go through these things, I will determine what I want to keep original/stock and what I want to upgrade or customize. I am pusing 160K miles on the clock and am still undecided as to how much I want to put into it. I love my FX, but I am at the point of deciding whether I should really make it nice again, or keep it safe and reliable and let my boys use it. I made an pic of how I would like to customize it that I will post later.
- fix or replace dash - cracking out of control
- fix tear in drivers seat bolster
