I had the Same Issue,
Make the sure the right front passenger door open correctly, i was like "I cant Pay for it right now " then I remembered that the problem started right after the passenger door lock wasnt opening correctly so I took out all the door cover and the motor was working fine but the cable that pull the lock wasn't moving forward/backward, so I relocated to its position and Problem Solved!
Yes for some reason if front right passenger lock is not opening my rear won't open until I reach over and manually open the lock then the rear will unlock. My lock issues are worse when it's hot out.
