I recently bought new wheels and tires (with new TPMS sensors) from Discount Tire. When they tried to reset the system, my old set of wheels/tires were in the car. I suspect this might be the reason why the system didn't correctly learn the new sensors.
When I start the car, the TPMS light flashed slowly for about a minute then stays lit. Does this indicate that it is currently in the "learn" mode? If so, is the solution as simple as setting the correct pressures on each corner?
