Torque app and OBDII reader
tomwetherald
San Diego
06 FX35 Sport AWD
So I don't see any write ups on here about the android and Iphone app for reading OBDII data. Not sure if this is the right category to put this in.
There is a paid and a free version of the Torqueapp in the android market. They recommended using the Kiwi Bluetooth adapter over some of the cheaper alternatives.
The torque site claims the following features:
  • View live OBD engine data on your Android phone – Connect to your vehicle ECU
  • Fully customisable dashboard screens – Design your own layouts and custom dials, use your own themes
  • Retrieve Fault Codes (DTCs) and clear Check Engine lights – View fault descriptions using the built-in databases
  • Upload live OBD2 data to your webserver or the torque web viewer in realtime
  • Check the performance of your vehicle with BHP / Torque / 0-60 & Quarter Mile widgets
400px-Torquehand.jpg​
View Live Data:​
The app gives you a few dials for starters, but you can add from a list of different dials graphs and displays. I also went ahead and changed the dials to an orange theme to match the dash in my FX35. There is a list of displays available, and if you’re connected to the ECU the ones with data have an asterisk next to them helping you choose the ones you want to display. Once you choose a display to add, the app gives you a choice of size.​
Issues:​
The dials do not update instantly, there is a slight delay before the displays show what is happening. I set the Faster communication check-box, but the dials still have a delay. for the logging feature this may work fine though.​
The free version of the app has quite a few sensors that can be displayed. I went ahead and got the paid version. It gets updates faster, and I think you have to have the paid one for the track recorder.​
Reading Fault Codes​
I have used the scanner to read codes for several peoples cars. not only does it read the code, but it also lets you click it and search for what it means. You can also email yourself the code info before clearing it.
Track recorder
There is an add on track recorder which you can use by mounting your camera on the dash, and connecting to the computer via the dongle. The recorder records the video and audio as you drive, with what ever gauges you choose to display on there. You can play back the video and see your rpm, speed or a number of other dials overlaid on the video.
These are stored in separate files on your device. but you can export the video to a file with the data overlaid.
///9366[/ATTACH]
Ill upload screenshots to this later. snagged these off the web :)
Hmm the app is saying its trying to connect then loses connection :(
That could be because you are using bluetooth. I remember hearing some people were having trouble using bluetooth on iphone if you have one.
I am thinking about picking up the wifi instead of bluetooth adapter. It is a bit more expensive but im guessing the connection will be faster.
So when you delete a CEL with this APP will the CEL eventually come back? I know that this is not a Tuning Software but i have used software in the past
where i was able to clear a cel and it would never come back.
If there is a problem with the specific sensor, the CEL will come back until the problem has been resolve. I normally scan for the trouble code, earase it. When the CEL engine light comes back, scan for the code again. It it is the same code as before, I will start the trouble shooting and replace/repair per the code description.
This seems to be the most popular of the OBD2 Bluetooth adapters and the one that I had:
I gave mine to a friend (because I like it so much). Now while search for a new one to buy, I find the one pictured below. I really like the small size. Has any one use this one and is it any good?
I was thinking about getting that small one, but I chose the more popular one instead (first one)
I was worried about the adapter hanging down too low from underneath the steering column so I took a chance on a small black Chinese knock-off version and it works perfectly with my 2009 FX35 and the Android Torque app on a Motorola RAZR MAXX. $13.20 USD. Just search for "Super Mini ELM327 Bluetooth V1.5 OBD2 Car Diagnostic Interface Tool" from dx dot com.
Is it about the same size as the blue one pictured? Smaller is definitely better as long as it still works good. I remember that the standard size orange one was a bit in the way. I hate to complain because I really like it, but smaller would be an improvement.
I use a 90 degree angle OBDII extension/adapter.
