Top speed Pro 1 exhaust???
2011 FX50S
Orville
While browsing the internet earlier, I previewed a video of a FX50 with a Top Speed pro 1 exhaust. It sounds a bit more aggressive than the borla, but I would like to know if anyone has experience with this exhaust. The top speed site lists both the y-pipe and axle back for the FX50, but can anyone here verify that? Would it be a direct bolt on or require some modification? Thanks.
Are you sure it wasnt just Arc? because it also sounds more aggressive than borla
The video said Top Speed pro 1 on a FX50S. Not sure how they could confuse that with Arc. I realize the video sound could be different from live sound though.
Decided to try the Top Speed exhaust; y-pipe plus axle back. Installed it over the weekend and had to make a few modifications for proper fitment. Welding and Machining skills definitely helped. I bought it for sound effects and I am pleased so far. It certainly has a wide range of different sounds, depending on gear and rpm, but at least I can actually hear it!!!
I will try to post a video clip when I figure out how to do it while driving.
I also have the Top Speed pro 1 exhaust, what modifications did you make? Mine makes contact with the rear chassis brace and trying to determine the right course of action.
I had to remove 4" from the center pipe. My exhaust was sitting on the brace and wouldn't budge when I used force, but after shortening the pipe it fell in place. I hung the rear section and y-pipe, then measured the space to see how much I needed to remove.
