This took me 4 days. The plastic was pretty badly pitted from years of road abuse. Sanded it down with 400 grit paper, then sprayed with a filler primer, sanded that down with 600, sprayed over again, 1000 grit, then 2 layers of paint, 1500 grit, 2 more layers, then clear coat, 4 layers, 1500 and 2000 grit wet sanding, rubbing compound and waxed to give it a shine.
I didn't want to feel any bumps and uneven areas, this is so smooth even I'm sporting a big ass grin
). I let the primer dry over night before sanding it and painting, and same with the clear coat, wanted give it enough time to harden and cure. It's night and day in the way the plastic pieces feel. Used up total of 2 spray cans for primer/paint/clear coat.
---------- Post added at 01:54 PM ---------- Previous post was at 01:53 PM ----------
Here are all the pieces painted with primer and sanded down
