superchager question.
sch4400
Los Angeles
hi i hav some question about lms s/c
i have 2005 FX35 and trying put used s/c, but i hav no information about s/c, my budget is $3500 include install.
wat i wanted is lms, i dont really wanted the stiilen or vortech on my car.cuz I dont have enought money and i just want my car at 300whp(like 2008 G35 or 2009 FX35). i dont wanted to damage my car by putting too much hp into it.
can u just tell my all the thing that u want me to know about, and any kinda concern, and any informations that is pretty important.
ill waiting for ur r/p thx.
I think you are confusing HP and RWHP. The newer G/FX with the HR motor make around 300 HP, but not RWHP. They only make 20 more HP than our FX's with the DE motor. You can get up to that with simple bolt ons. I believe the HR runs in the 250's for RWHP. 300 RWHP is adding around 80 over stock, so there shouldn't be any problems. I believe the HKS is known for lower HP numbers with low risk, so it might be a good option for you, and you didn't mention it.
///1861
I guess you are going to or bought one of the only 2 FX35 LMS superchargers out there. If you are in LA I suggest taking it to Steve at LMS and have him do the install since they built it and can tell you all the things you need.
SCH4400 sent me a pm -
He talked to Steve from LMS and they wont touch the UTEC.
So He called TS, and wants to know if TS can install the kit and get the UTEC working.
My guess is no. But I'll post it here so he can get his answer as I know nothing about Utec and F/I
Technosquare won't tune a utec. They can flash and tune off the stock ecu. Installation of the LMS kit is not an issue, I would go with a different blower unless LMS is using something that is still in use? I thought the powerdynes were gone but now supported by another manufacturer.
if TS installs the LMS I don't think he would need the UTEC, they could just flash his ecu and that would be better than just running off the J&S alone. Would also need to install the LMS fuel controller though.
either way, expect to pay more than $3500 cause custom tunes are not going to be cheap if they know what they are doing
charger plus a tune alone is going to be $3400-$3500 then add install to that and you will probably be over $4000
You can install the LMS kit as is and steve can do it but then that motor will depend entirely on the knock sensor functioning properly. If it goes out, chances are so will your motor. Same goes for the inline aux. fuel pump, if that goes out so may the motor if under boost.
If you really want to be safe it's gonna cost more
---------- Post added at 07:30 PM ---------- Previous post was at 07:27 PM ----------
928motorsports has the powerdynes and everything you would need to rebuild them.
They even have the conversion to the chain instead of belt driven. The chain driven is supposed to be good for up to 18 psi i believe
Does any one know which shop tune with utec?
a little google-ing goes a long way
found this from this web site
http://www.turboxs.com/dealers.htm
California
ARD Performance Motorsports
2222 Verus St
Suite B
San Diego, CA 92154
http://www.ardperformanc.com
Top-End Performance
7452 Varna Ave.
N. Hollywood CA 01605
818.764.6768
Advanced Tuning Products
3664 Edison Way
Fremont, A 94538
510.445.1682
http://www.8vturbo.com
Autobahn Designs
2900 Adams Street
Suite B 27
Riverside, Ca 92504
909.351.9566
www.autobahndesigns.com
Eastside Muffler
2619 East Palmdale Blvd
Palmdale, CA 93550
661.267.2648
GT Motorsports
8220 Masi Drive
Suite C
Rancho Cucamnga, CA 91730
909.989.2278
www.gtmotorsports.com
Wholesale Distributor
TurboXS Approved Tuner with AWD Dyno Facility
Harman Motive, Inc
340 Van Ness Ave
Unit E
Torrance, CA 90501
www.harmanmotive.com
AWD Dyno Facility
MPJ Performance
30909 Vanderbilt St
Hayward, CA 94544
510.487.4447
Next Level Racing
7150 Boyd Ave
Carlsbad, CA 92581
Pann Auto Peformance
7960 Ronson Road
San Diego, CA 92111
858.278.7266
www.pannauto.com
The Audio Experts HYPERformance
1600 E. Cypress Ave #4
Redding, CA 96002
530.221.6409
