Sunroof wiring
david
mississippi
Going to my sunroof controll I have a green, black, and brown wire. Anyone know which is which?
---------- Post added at 12:13 PM ---------- Previous post was at 12:13 PM ----------
After the plug the wires are red, yellow, green if that helps any
:hmmmm2: What are you trying to do the the sunroof controll? What is it that you're looking for from the wires?
Which is + - etc and which gets from switch to motor
Not working. Trying to determine us if it getting power
---------- Post added at 12:33 PM ---------- Previous post was at 12:23 PM ----------
I'm trying to run Wires with definite collage to see if the motor works. It may be the switch itself
Have you check the 15A fuses? #1 & #22 in the J/B fuse block by the parking brake in the driver footwell?
Yep. There was 1 bad fuse. Changed it already. No change. This happened when I did my own headliner a while back. There is really only one way to plug the stuff back up so I'm not sure what the problem is.
Im curious how/where I can buy just the switch with button. And try replacing that
The brown wire is the tilt function. While ignition on and tilt is press, you should get 12V make sure you ground the black lead of your mutli-meter.
The green (light green) is the slide open. Again , if you press it to open, you should get 12V
The black is ground.
---------- Post added at 03:09 PM ---------- Previous post was at 03:04 PM ----------
Part# for sunroof switch: 25450-AL50E
