FXtion, thank you for your help!!!!
So nice of you to put a manual and the pix of my amp!
I love Inifinitiscene.Only time I hated this site, is when I read too much good stuff and my credit card is itching....
Now I have everything that I need to install.
Just purchased Infinity Kappa 102.7w + converter and the misc wires/connectors.
Now I'll just have to wait until this weekend to install. I would rather not install or work on the car at night.![]()
Another happy and satisfied iS member!!! Kudos to you FXtion :top:
Oh yea... guys one more question sorry !!
how many feets would i need for the ground wire ???
hmm... i don't want to be all short afterwards running the whole wire to the back...
Sweet UPS man came by today to deliver my Kappa 102.7w sub.
It has 1ohm or 4ohm selector switch. So very easy to wire.
I will post some feedbacks after the install.
Good luck with the install !!!
Im planning to start my install this weekend !!
Yes, the 2 positive L/R go together, and the Negatives go together. No Y-Cable needed.I just have couple of things that I want to clarify before this install.
Amp model : Hifonics Zeux ZX6000 2CH amplifier. I will bridged to MONO 4ohm.
I am going to connect 1 Infinity Kappa sub @ 4ohm.
From the amplifier user manual, " A MONO signal source is required, such as would be available from the mono sub bass output of an active crossover, whether standalone, or built into a headunit or EQ...... It is necessary to feed the SAME signal to both left and right inputs via a Y-adapter RCA cable"
What is this suppose to mean???
Also, I have purchased PAC SNI-35 Line out converter. This unit has 6 wires.
2 wires for RCH + & -, 2 wires for LCH +&- and 2 ground wires. 2 ground wires can be discarded.
Now the bose wiring:
Subwoofer signal: Positive- White
Negative- Black
Amplifier Turn-on- Pink
So do I connect both +,+ to the WHITE and -,- to black?
Thank you for your help.
