StopTech/Centric part numbers - Gen I
jumbosrule
Fully FX Invested
Premium
Redondo Beach, CA
2003 FX35T
Brad
I just did some research and figured somebody might find it useful someday...
2008-2003 ST40 4 Piston Color, 355x32mm Slotted Rotor, 309 pads BBK Front 83.486.4700.X1 $ 2,995.00
2008-2003 STR40 4 Piston Trophy, 355x32mm Slotted Rotor, 309 pads BBK Front 83.486.4700.R1 $ 3,750.00
2005-2003 Rotor, StopTech Sport Slotted - Left Front Left 126.42080SL $ 136.50
2005-2003 Rotor, StopTech Sport Slotted - Right Front Right 126.42080SR $ 136.50
2008-2005 Rotor, StopTech Sport Slotted - Left Front Left 126.42092SL $ 124.50
2008-2005 Rotor, StopTech Sport Slotted - Right Front Right 126.42092SR $ 124.50
2008-2003 Rotor, StopTech Sport Slotted - Left Rear Left 126.42078SL $ 95.00
2008-2003 Rotor, StopTech Sport Slotted - Right Rear Right 126.42078SR $ 95.00
2008-2003 Stainless Steel Brake Lines Front 950.42000 $ 71.95
2008-2003 Stainless Steel Brake Lines Rear 950.42500 $ 60.95
2008 Axle Bearing and Hub Assembly Rear 400.42006 $ 182.75
2008-2003 AWD - Axle Bearing and Hub Assembly Front 401.42006 $ 185.75
2008-2003 RWD - Wheel Bearing and Hub Assembly Front 406.42010 $ 169.75
2005-2003 StopTech Sport Brake Pads Front 309.09690 $ 73.95
2005, Fr 11/05: StopTech Sport Brake Pads Front 309.08880 $ 85.00
2008-2006 StopTech Sport Brake Pads Front 309.08880 $ 85.00
2008-2003 StopTech Sport Brake Pads Rear 309.09050 $ 64.50
2005-2003 StopTech Street Brake Pads Front 308.09690 $ 73.95
2005, Fr 11/05: StopTech Street Brake Pads Front 308.08880 $ 85.00
2008-2006 StopTech Street Brake Pads Front 308.08880 $ 85.00
2008-2003 StopTech Street Brake Pads Rear 308.09050 $ 64.50
2004-2003 Centric Loaded Caliper Housing and Bracket Front Left 142.42124 $ 96.70
2004-2003 Centric Loaded Caliper Housing and Bracket Front Right 142.42123 $ 96.70
2005, To 10/05: Centric Loaded Caliper Housing and Bracket Front Left 142.42124 $ 96.70
2005, To 10/05: Centric Loaded Caliper Housing and Bracket Front Right 142.42123 $ 96.70
2008-2003 Centric Loaded Caliper Housing and Bracket Rear Left 142.42564 $ 96.70
2008-2003 Centric Loaded Caliper Housing and Bracket Rear Right 142.42563 $ 96.70
2006, Fr 11/05: Centric Semi Loaded Caliper Housing and Bracket Front Left 141.42148 $ 96.90
2006, Fr 11/05: Centric Semi Loaded Caliper Housing and Bracket Front Right 141.42147 $ 96.90
2008-2007 Centric Semi Loaded Caliper Housing and Bracket Front Left 141.42148 $ 96.90
2008-2007 Centric Semi Loaded Caliper Housing and Bracket Front Right 141.42147 $ 96.90
