...steering question...
calmplex
805 CA
whaddup iS!?
Not sure if I'm experiencing a problem, or if this is how it's suppose to be so I thought I'd ask the community before taking it back to the dealer to check out...
...I've noticed the last couple days that when i drive over small bumps, or road that is uneven the steering wheel will move left/right as if it's following a groove... causing me to hold the wheel a little to make sure I stay straight... is this normal? I say that because I'm coming from a 03 Toyota Highlander (don't ask, stupid girlfriend at the time convinced me to get it) and I'm not sure if it's just me having to get use to the fatter tires and handling of the car... I browsed the forums to see if anyone had similar problems but nothing really close to what I'm describing...
Everything is stock on the car, tires look good... any suggestions on what it could be? Or what I could tell the dealer to look at? I hope it's not a major issue/fix since I just got the car a week ago...
Thanks in advance iS!
This is called "hunting." The FX's suspension set-up will make it follow lines or grooves in the road.
This is normal. Different tires will react to this differently...
...thanks for the quick response...
...I'm glad I checked in here first before calling the dealer... again coming from the worlds most boring stupid suck car to this is a complete shock to the senses...
