Stealth FX v2.0
Status
Not open for further replies.
Finally the long wait pays back. What a hot FX!!! Sorry to hear what you have gone through. Why did the body shop need to drill a hole on the the passenger side wheel well?
John... They needed to drill down the inner wheel well since there is nothing to hold it up since the front fenders were modded..
In that process the use screws to hold up the lining and with it took out the wire harnest...
Thanks to all for you support.
Since I have a 3 piece wheel iforged uses a seal that goes on the outer wheel where the 3 pieces meet.This seal is no good and I am looking tire pressure.
I plan to drop off the wheel tomorrow and have them redo the wheel. They tell me that I should get the wheel back by Mon or Tues of next week since this is a holiday week.
wow, amazing that the seal is leaking on a new set of wheels. I'm actually having the same problem with a set of HRE's no less, but for my other car, not the fx... really funny the way HRE did this set of wheels, a defect from them in the way they drilled it for the tire valve but they want to have no part in it... pss, even going with one of "the best" in wheels is no guarentee that you still can't have "issues". hope Iforged customer service does right by you...
when I was looking at wheels, I was researching 2 piece vs 3 piece. I ended up getting 2 piece wheels for the seal issue -- but the places I called said it would have to be serviced about every two years to make sure there isn't a leak. A leak right after getting the wheel -- that's rough.
All in all, car looks great.
When are we gonna see a Humberto, rookie, and turbocad photoshoot?!! Jk, good luck to all of you guys. You guys have the best FXs.
That'd be rough considering there's ~2800 miles between the two :tongue:
BUT... Chicago is a good 1/3 the distance from NY to CA, and a good 2/3 the distance from CA to NY :tup:
I'm just sayin...
Status
