Starting issue
FX-Owner
2004 FX35
Mike
Hello everyone,
I have a 2004 FX35, recently I have starting issues. The engine turns over, engine fires up but then wont stay running. the only way to get it going is to give it some throttle once the engine fires up. once I get it running the vehicle runs and drives fine.
Anyone ever have this problem?? what was the solution to fix it??
I'm not having this problem, but recently experienced something similar where my engine is sputtering at low engine RPM almost cuts off. I noticed one of the drive belts is worn. so I'm going to replace it and see if it remedies this problem.
Have you pulled codes and checked your plugs/coil?
