[sprtfx] Custom made LED lights
Status
Not open for further replies.
Here are a couple of pics (before and after) of the rear interior roof lights and the rear cargo area lights. I love them ALL! They look so great with the license plate and map lights I already purchased from you. Thanks :)
I have all leds in my interior, I will say this. My wife and daughter both bitched about the vanity lights on the mirrors that they could not see as well with the leds and as a result I put back in the old lights for them. All in all, I love them and think its a great improvement over stock.
I did notice this to be the case when I used the mirrors in my last FX and my VW Beetle. I might end up leaving those... depends on how much it bothers me that they differ from the rest. They'll probably end up being LEDs though, lol.
What packages are available now? Interior gen I - interior Gen II?
sorry for late response. interior package is on the way. I know couple people are already got them from me . I just haven't get the chance
to shoot photo of them as a group package. bear with me.
photo should be up end of this week.
The board are etch, now going to cutting stage.
Update!!
package now available. allow a week to build.
package is 130 shipped.
for those already have plate light from me and just want the rest.
price with out plate light is 105 shipped.
little more detail on how to install glove box light
REMOVING.
remove black plastic cover by pulling it down. should pop righ off the holding clip.
remove holding screw and 2 side plastic cover.
remove 6 screws that hold the glove box. 2 at bottom left and right 4 at top
now your glove should be able to drop downward, may need little push to
clear holding clips. unplug your stock wiring to glove box light.
INSTALLING.
lining up where you want your ligh location. I would try to put them in center.
draw straigh line and spot where you led will be.
Drill the spot you marked. about 1/4 inch hole should be good.
( NOTE: I drilled my little too close to the front so you want to do your where the line is.)
line up your led with the hole. peal off double sided tape to hold it in place.
remove stock bulb and plug in the new one. plug your wiring back on the car
to test it. don't put all the screw in yet. just test make sure the power up and line up with
the hole. if no power. just unplug and re pluge opposite way. (LED is polarized)
and enjoy!
Status
