santiagodraco
- Austin, TX
- 2010 FX 50s
I think you'll be happy with the results. Remember that adding in a processor will take it to the next level, can't beat a good processor tune.
I'd suggest a change however. Instead of buying HAT Imagines for front and rear instead buy ONE set of Imagines and one pair of Hybrid L3V2. Or better yet check with your dealer on the price for one pair of Clarus 6.5 for the door (just the midbass) and one pair of L3V2 for the dash. This would be a fantastic comb and I would NOT do anything with the rears except disconnect them
(or leave them for fill off the bose amp if you have people in back or run 5.1 content from a DVD). You'll be close in price range but you'll have a great sounding system. Not worth spending money on rear fill imo. What you want is the Alpine running the 6.5 midbass in the doors and the 3.5 inch or tweeters in the dash. Be sure they set the gains properly so you don't overdrive the dash speakers.
As to the existing.... ;I would disconnect them all and just run the front stage from the new speakers. You can, if you want, leave them hooked up and see how they sound. But from a "sound quality" perspective you'll achieve much better results without them active.
Rear speakers are good for rear fill if you carry around passengers but in reality they would probably hear your front stage just fine
The integrated bose system does use the center channel, mainly for voice, so if I left anything it would probably be that and leave it on the bose amp.
One thing you'll have to decide is how you are going to grab the signals from the existing headunit. If you get an integration preamp (100 bucks or so, such as the Audio Control unit mentioned earlier) you can pickup the signals from the existing speaker outputs from the Bose amp. If not you'll need to use the service manual wire diagram to pickup the line level signals going INTO the bose amp and run those to the new amp/processor. There are threads here on that. You don't want to use the Bose speaker level outs if you have a processor since this will be double processing.
Hopefully this wasn't too confusing!
