Service maintenance alert
Pupp
Premium Member
Premium
Shitcago
When you reach a service interval on the maintenance screen is there any warning or alert light that comes on in your FX? I reached the first service interval at 3750 but I didn't notice any type of alert or light on the dash or elsewhere. Is that normal?
it could be set at 4,000 miles or something.
Doesn't the screen for the Nav system come up everytime your turn your FX with a huge sign Maintenance, when it's overdue?. My does..
Did you check if it was off or disable
The small arrow on the maintenance screen indicates 3750??
That's what I was expecting. I will look into the settings. Thanks.
For the oil change and tire rotation maintenance reminders, when you select either of those options make sure the setting that states something like "Display Notification" is clicked on. Now every time you start the car a big green wrench will come up on the screen telling you which option needs service.
There are no maintenance displays for the major tuneup schedules per say, i.e., 15k,30k, etc...
There is an elective maintenance indicator on the nav screen should you choose to have it come up at certain predetermined miles.
Thx guys. Appreciate it.
