http://www.scangauge.com/
This is a pretty good tool for anybody that mods cars or just wants to keep stats on their car. Just throwing this out if you are looking for a scan tool.
Features:
Also with the new xgauge feature you can have additional gauges on it... like horsepower, trans temp..etc. http://www.scangauge.com/support/xgauge.shtml
I bought mine cheaper on ebay.
Features:
TRIP COMPUTER Automatically tracks four sets of trip data - Each with 11 individually stored parameters.
DIGITAL GAUGESDisplay 4 gauges at a time from the 12 built-in digital gauges. the information is presented in Real-time!
- Maximum Speed
- Average Speed
- Maximum Coolant Temperature
- Maximum RPM
- Driving Time
- Driving Distance
- Fuel Used
- Trip Fuel Economy
- Distance to Empty
- Time to Empty
- Fuel to Empty
SCAN TOOL The ScanGaugeII allows you to troubleshoot your own car, read error codes, and the conditions present when the error occurred. You can also turn off the “Check Engine” light and avoid those costly trips to the mechanic.
- Fuel Economy
- Fuel Rate
- Battery Voltage
- Coolant Temperature
- Intake Air Temperature
- Engine Speed (RPM)
- Vehicle speed (MPH)
- Manifold Pressure (not available on some vehicles)
- Engine Load
- Throttle Position
- Ignition Timing
- Open/Closed Loop
- Reads Trouble Codes
- Reads conditions that set the Trouble Code
- Clears Trouble Codes
- Turns off the "Check Engine" light
- Tells you when vehicle is "Ready" to pass OBDII testing
- Make and store up to 10 rewritable special codes
to send to the vehicle computer
