Satellite radio upgrade again
embdenb
Weeki Wachee
2005 FX35
I know this has been covered before, but all the links are either dead or the part is no longer available.
I have a 2005 FX 35 (Tech package) with a Satellite button that says "No Satellite" when I press the button. Is there a current vendor that sells the parts to upgrade this unit to full Satellite functionality while maintaining the factory look?
Thanks for your help.
It might be available through the dealer... Even if the links are dead, the part #'s should still be in the post... You can still check the online parts stores to see if you can order them... Or ask your dealer, but they're kinda dumb and will probably mark up the prices IF they can even order them... For the SAT module, I believe it's one module and 2 harnesses...
