scotthall1515
I should also add that my new cargo area cover arrived from Lloyds. Will be adding a secondary subwoofer cover to the Morel that will be used when travelling so that the floor will be fully usable. The cover will come off when showing off the car.
---------- Post added at 08:42 PM ---------- Previous post was at 08:32 PM ----------
Hi there. Replied to your PM earlier. Very sorry for missing it for so long.
For those wondering about the wiring interface to the head unit on the FX. All you need to do is get the service manual. It's available online. The wiring interfaces for the amp are very clearly listed.
Here's the good part.
The stock HU does output Line Level. You DO NOT need to pick up signal from the Bose Amp. You can pickup signal from the HU itself. I interfaced at the Bose amp in the back, picking up the line level signals where they entered the bose amp (ie tied into the wire before the connector). Then take the line level and run it to your amps/processor/whatever.
A few other things.
1. The HU line level is fairly low, so you will need to raise gains a bit to compensate.
2. Each speaker has a discrete wires if you chose to use these without rewiring (which is fine for most uses).
3. There are line level signals for front left, front right, rear left, rear right and center. There is no sub signal from the HU so you will need to split that using a processor or filtering on the amp itself.
Any more questions let me know. Again, sorry for letting the thread stagnate. I know how frustrating it can be knowing someone has done the work and has answers to the questions that seem to be hard to find out there.
I just want to say thanks a bunch for all the advice installed one amp preparing for the third one.
Sent from my HTCONE 4
