from scale of 1-10, how hard would taking off the muffler compare to like installing outer tie rod?fml, if its from the cracking and not dealer, dont know when ill have chance to install bbk,rims etc. inspecting the rust on my exhaust, its not as bad as i initially thought, way less on the exhaust itself, more on other part,metal,frame surrounding around it.
Its not hard if you can raise your car on jackstands and get one other person to help wiggle the muffler. If your a smaller guy like me you may be able to remove muffler without lifting the fx. Some wd40 and it should slide it right off the hangers. The hardest part is that the bolts holding it to the midpipe might be really rusted and may break when you remove the muffler.
Sent from my SCH-I510
