Running rough, Code P0306, Already replaced coil and plugs, HELP PLEASE
spdfrek
florida
Did a tune up and replaced the spark plugs with NGK Iridium, drove about 100 miles and it was good, shut car off, when I started it again it felt like it was running on 5 cylinders. So, autozone pulled a code P0306. I then replaced the back drivers side coil pack (#6), cleared the code/reset ECU. It's doing the exact same thing and not sure what to do.
What should I do next?
Thank you!
Did you check to make sure all the vacuum hoses are plug back in and nothing cracked? Intake hose, PVC hose
Crisis averted. When I took everything back off to switch the coils I noticed #6 wire wasn't 100% attached. It was 90% though.
FIXED!
---------- Post added at 05:02 PM ---------- Previous post was at 05:02 PM ----------
Thank you for the help and response!!!!!!!!!!!!!!!
FIXED!
I was going to say that exact same thing. PUSH IT IN GOOD :smile (2):
