- Atlanta, GA
- 2007 FX35
He's not wrong, but you're not wrong either. Holes whether cast or drilled can result in rotors more prone to cracking. Most OEM drilled rotors are cast with holes like Porsche and their rotors do crack sometimes. Almost all aftermarket rotors are drilled from blanks and the chances of cracking will depend on how the work is done. These days, the chances are far less since they typically chamfer the holes to reduce the stress risers. This wasn't always the case, I had Brembo's over a decade ago and their holes were not radiused at all.
I've personally never had an issue with any of the drilled rotors I've had over the years, but I know people that have. No one's ever had a rotor totally fail, but I've seen some with cracks starting around the drilled holes. And parts choices for racing are different than parts choices for street cars. Just because a rotor doesn't fail during racing doesn't mean it's not more prone to fail on a street car. In racing, you're not doing a bunch of start/stops or driving through a car wash with hot brakes, etc. Plus I doubt you expect your rotors to last tens of thousands of miles. And if you want to see pictures of cracked rotors from racing, just look at Porsche's. There are quite a few pics of GT3 rotors cracking at the track. Still not common, but it does happen.
In theory, drilled rotors are weaker than non drilled and more prone to crack. Basically you've removed material and introduced areas of potential stress. In practice, there are a lot more factors.
