Replacing the throttle body.
rivets
CA
FX
The current one is damaged and I need to replace it with an OE unit. Other than the standard pedal resets (ECU Reset, Accelerator Pedal Release Position Learning, Throttle Valve Closed Position Learning, and Idle Air Volume Learning) will I need to do anything else that will require taking it to the dealer? It should just be a plug and play swap, right?
Going to buy this:
GENUINE OEM Hitachi Throttle Body for NISSAN INFINITI FX35 G35 161198J103 S20058 | eBay
