This is an ongoing problem for me, the factory remotes started to stop working so i replaced the battery, worked for a couple of weeks before it started again.
Replaced the battery again and pattern repeated itself.
I ended up carrying the spare batteries in the car as a backup.
I finally gave up and bought some OEM remote`s and got them programmed, they worked beautifully for a month and now they started doing it again and none of the keys will work - interestingly the only button which works is the Alarm button.
At times i can open the remove and clip it back and it will work for a couple of days then stop again.
Is this something wrong with the car, something failing that's causing this issue, i find it hard to believe it is a unique issue for my 2017 qx70s.
Any advice from masters here is highly appreciated.
