rear wiper, only OEM can fit ???
hangout
New York
Infiniti Q70L
need to change the rear wiper on my 2003 FX,,
I'm wondering if the OEM can fit on the arm, or I can buy the aftermarket 13"..maybe even bigger :)
any idea?
Thanks
rear wiper, only OEM can fit ??? <-skip this one.. ;)
rear wiper Blade?
rear wiper Blade Replacement
K... There is a cap where the elbow that connect to the hatch. You will pull on the side of the cap and pull it up.. Loose the arm up. Pull the arm up steary preassure. U don't have to remove the arm completely. Just rotate it down toward the bumper and bend it up.. Then you can remove the blade and put the new one.. This is just a general explanation.. I'll step out at lunch and do it and explain it better..
