Rear hatch lock & motor failure
speedyjp
HB in the OC
couldn't post in a related thread so here goes...
dealing with the failed rear hatch lock/motor. stupid prob is it failed in the open position so i had to tie my rear hatch down. i'm awaiting part quotes on the lock assembly and motor. from the diagrams, looks like i may be able to do myself. but i'm gonna check fuses first but don't think that's it.
fwiw - i had both passenger side door locks fail on me in the past. they could only be locked and opened manually from the inside. i recall paying upwards like 700 bux to fix both freakin doors.
Hi:
I have almost the same problem, the front passenger and rear driver's lock are lazy, and sometimes don't want to lock. I'm learning in the DIY, some guys has bought some universal 12 v. actuators on ebay.
It seems not very easy to do, but the dealer price is >200 € each lock actuator, so I'll try to do to my FX.
My back hatch was locking intermittantly I sprayed some lubricant in lock mechanism and it seems to have fixed the problem.
Mine acts up every now and the then. I pull the fuse, I believe its label as "back door" in the drive foot well area, and plug the fuse back in and it works again until the next time.
After all these years, I finally had the Hatch Latch problem. Over the last few weeks, the button to open the rear hatch would not work intermittently. I noticed when it would physically unlock and open on occasion, the open/close motor would not make the open/close sound.
Today, I pulled the fuse and put it back in, and sprayed copious amounts of WD40 all up in and around the latch. The locking and opening works now, even though it still needs long term testing to prove out. Interestingly though, I now hear the open/close motor working again. So, something definitely works after the fuse+WD40.
