Rattle Can Paint Job (Ultraleggera's)
Jeff, how did you manage 4x8.5" wide rims? I see them sold staggered on tirerack. Would the 20x10 et25 be too wide for us? Stick out past the fender? If not I'm really considering the 20x10's if I can manage to get a set of 4 and then powder coat them black...
Edit: based on offset calculator... 10mm extra going inward and an extension of 40mm OUT? Like using 40mm spacers on stock 20's??? :eek:
You can add all, then adjust the quantity on the shopping cart. Just reduce the quantity of 20x10 to zero and 20x8.5 to 4. I wish the 20x10 came in around 30-35 offset. I wouldn't even think about 22s if it was..
Btw, if you select a lexus GS as the car, there's 20x10 +35 ultraleggeras but they're $439 a piece. Can't you get these and then ask for Infiniti centering rings from tirerack?
i like i like, any pix on your ride ?
nope, not yet.
Yup, as EG3 stated, just edit the cart quantity on check out.
:tup:
If you find the right dealer you probably can. But they really don't like selling anything that changes it from their stock way of selling it. When I told them I was putting these on an FX the guy said he will mark that down on the invoice and it will probably affect a return if I had to return them.
That's retarded... hmphhh...
Yeah I really want the 20x10's, especially at that killer price... maybe if I go wide-body I can still do it? :tongue: Thanks for the info on how to order.
^^^ looks hot it looks like 22"s care to share a bigger pics of it on ur car plsss how much did it run you for the set up?? are you running 265 50 20???
Once I fix up the car and cut the springs I will show better pics. (Whenever that may be:frown:). Tires are 275/40/20's.
Heck with it, here is a bigger pic, (Gap Kills:tongue:) - Eventually it will be dropped more.
^^ downside of 275/40s = more gap.. I got used to it but I think I wouldn't do it if I didn't have the 22s.. Also I still like those Ultraleggeras.. If I ever sell the 22s or OEMs, I'll get those in 20x10 size.. Yours look very good, btw :tup:
Thanks, you should get the 20x10's less weight and on sale :fever:... 275/40 is a hot tire though minus the gap, nothing a little cutting won't take care of.
right
the rim looks good in a 20, just overall it does't have enough meat to it
---------- Post added at 03:55 PM ---------- Previous post was at 03:46 PM ----------
one of the first thing to turn me onto the FX is how enormous the wheels and tires look.
if they keep getting smaller it'll start to like like this
I agree w/ the small tire... ever since my lil experiment with smaller tires (I went way more extreme than Jeff here) I do love the fatty rubber look:
(that's lowered on Eibachs btw)
