quick questions!!
hey guys!
my question is,
is it okay to put 30mm spacers in front and 25mm spacers in the rear? even tho its an AWD?
i have 25mm all around right now but wanted to go with 30mm in front to look more flush
because i heard that you are not supposed to go with staggered fitment or different offsets for AWD system
please let me know! i did see few members here have AWD with staggered wheels..OR GTR wheels :)
I have an awd fx and I had 30mm up front and 25mm in the rear with no problems but now I have gtr's and still no problem. Spacers don't mess with the awd its the tire sizes that plays a big part.
Sent from my HTC 2
+1. As long as the tires are of the same diameter, you should be fine.
The tires just have to be within a certain % of each other. I'm AWD and I run staggered 22"s - 9" in front and 10.5" in rear. I've also played around with different spacers too. Never had an issue.
+1, as others had stated: adding spacers will merely widen your stance. Since your wheels/tires remain the same, it's not a stagger setup.
