FXsilverbullet
- calgary
Just installed these in my fx45 a couple weeks ago i have gained 1 mgp in the city. averaging 15mpg with a pretty heavy foot. im up to 22mpg on highway going 70mph. both of these results were based on one full tank aproximately 20 gallons at fill up per test. as not to mix resullts. I bought my set of 8 off of ebay. http://cgi.ebay.com/ebaymotors/Puls...ryZ33693QQihZ017QQitemZ270228103501QQtcZphoto
Can any one tell me how to post pics. Ive done a driller rotor install and would like to show results. Thanks.:xd::xd:
Model: DG-1
Qty: 8 Pulstar Plugs
Thread: 14mm (5/8" Hex)
Reach: 26.5mm (1.04")
Seat: Flat
Applications: Infiniti, Nissan, Subaru, Mercedes
Years 2002-2005
Pulse plugs are a radical departure from spark plugs. Pulse plugs incorporate a pulse circuit, which stores incoming electrical energy from the ignition system and releases the stored energy in a powerful pulse of power. Instead of 50 watts of peak power typical of all spark plugs, pulse plugs deliver up to 10 times more peak power. It takes electrical power to light fuel. The more power (watts) the better.
Pulsed Power Technology is the science of storing power for a relatively long period of time and then discharging the stored power in an instantaneous pulse of energy. Installing Pulsed Power Technology in a performance auto part increases horsepower while at the same time increasing gas mileage! That's right - you no longer have to give up gas mileage to increase the power and productivity of your car or truck!
A simple way to think about the Pulsed Power Technology behind pulse plugs is that it is similar to a camera flash, whereas spark plug technology is more like a flashlight. A camera flash is exponentially brighter than a flashlight even though they both may use the same battery.
Ignition velocity refers to the growth of the combustion flame front, the speed of which determines the amount of energy released from the fuel. The greater the amount of ignition energy the larger the spark. The larger the spark the more efficiently your engine can operate to produce horsepower or, inversely, better fuel economy.
Model: DG-1
Seat: Flat
Years 2002-2005
