- 09 FX50
Many people have begun to get the OEM aero kit.
I've had it for a while, and noticed a few issues with it before the most current problem.
- The fitment is not the best, and it takes some effort to get it to fit perfectly.
- The mounting points are not terribly secure; there is still some movement when installed.
- The mounting points under the car are simply screws drilled into the plastic with not securing bracket or nuts on the other side.
- The flimsy plastic on the mounting points can easily be bent and broken.
- glue is needed to fit the top portion, with the only mounting points being on the bottom of the lip itself.
However, my most current problem was probably a worst-cae scenario and I'm happy it did not cause an accident or any harm.
I guess the factory aero kit wasn't actually made to withstand high speed driving for long periods of time...
I Drove to boston and back last week; on the way back, on the highway, while doing around 90, the front lip came off of the car, went under the car, and out the back. I drove back around to go pick it up.
I did not hit anything; I did not hit anything the day before nor did I ever hit anything in the front so there is no reason for me to believe that something was wrong with it. it just came off the car while I was driving.
Upon inspection after I got home: the mounting points on the lip itself all broke and the body glue on the two parts connecting the top portion did nothing to save it.
replacement cost is $700 installed. I've ordered a new one and it should be in next week. I will be working on making additions to the lip in order for it to be more supported and less likely to fall off again.
These are all problems.
With an Aero kit, shouldn't it be made to actually withstand speed and promote the aerodynamic flow of air?
I know the pictures don't really do anything but show the damage, but this was a scary ordeal - the lip came off at speed, I ran it over, swerved a bit, and watched the lip flip around the road in my rear view, almost causing an accident.
When I went to retrieve the lip, it was in two pieces and cracked and scratched all over - I could not find the driver wheel well mount.
The new lip should be in next week. I will be making additions to the design and install of the lip to ensure a secure fitment and proper mounting to avoid any issues in the future.
These include the following: (the list will most likely grow)
- Reinforcing the mounting location
- Nuts on inside of mounting screw/bolt location to ensure it does not slip out.
- Addition of a lightweight sheet of plastic/metal to add to under-lip aerodynamics and promote air flow.
- additional mounting on top of lower bumper openings (currently only mounting lcoations are on bottom; glue on top)
- Possibility of molding lip to bumper at body shop
- Possibility of using rivets on lip.
This thread will be updated with these design additions for all of those who wish to do the same to do so.
