Problem with shift lock an
Knockout
Poland
FX35
Hi Guys,
I've got problem with shift lock, I'm not able to change it from P. I thought it's caused by bad solenoid, but after changing it problem still exist. Moreover I found strange things, when I get into the car, close the door and seat is starting moving to remembered position if I press break pedal seat is stopping moving. I can move seat by pressing buttons on seat but memory button are not working when brak pedal is pressed. I've checked switch under the break pedal bit it seems to work fine (stop lights as re working fine). Also I've checked diagram and it seems that shift lock and memory seat has nothing in common but in my case they are somehow connected. Does anyone had such problem or know what else I've should check?
https://photos.app.goo.gl/TsMjE8Ae3yiCqCmi7
