It does, thanks. I'm running the re-Q off the power i ran from the battery and it seems to work fine with just constant, ground and remote switch from factory brown wire. I'm sure i'll be ok with this set up.
Do you know the color wires for the rear speakers so I can splice intp them for the bass signal since using the sub wires is kinda pointless?
Thanks,
Josh
PS. I guess I need to run heaver gauge power as my 1 sub amp, Punch 320, is causing the interior lights to dim when the bass hits.
